kinematics
  • Thread starter Thread starter Marco_1980
Marco_1980
Good morning to all,
I'm new to the forum and I still don't know how it works. . .
My problem is this:
I have a cam opening a valve.
how can I simulate the opening of the valve with the kinematics module if initially the cam is not in contact with the plate?
Can I tell the program "ok.... at first the cam turns free for tot degrees and then comes in contact with the plate and opens the valve"?
to help me get crazy....
actually. ..but it would be enough to read the instructions...type presenting etc...
My problem is this:
if you do not want to study the dynamics of contact you can create a formula that binds the corner to the race. for which the race will be zero for the corners from x to y and then sinusoidale from y to z.
You're right. I'm sorry for everyone. I'm cheating on me, and I'm planning mechanical systems. .
...as for your answer now I will try to do as you tell me...but it would be possible to ask the program to "see" contact only when it actually occurs? . . .
Thank you for the answers and... I'm sorry again.. .
Mar
...an example is worth more than a thousand words. . .http://www.cad3d.it/forum1/showthread.php?p=170879#post170879
Mar
credo si can fare, ma non ricordo come
