label tolleranza
  • Thread starter Thread starter aerox
aerox
hi to everyone, I can't do one thing: is it possible to insert tolerances with a certain label? or by selecting a h7 type to automatically display the class and deviations. for now I have the quota and manually add the shocks but I do not have the h7 label.
to set the labels I saw that once the part file is opened, click on the change->set menu: now select "tolerance tax": in the new menu I choose "standar" and change from anxiety to iso. now select in "Table Toll" the item "Recover" and I load for example hole_h. If I now go into the model and go to change the quota I can choose the h class and the number I need (e.g. 7) only that I can not choose to display the shock values because the option way tolerance is in gray on nominal. Any ideas? ?
in the config there is the option tol_display and must be set on yes.
Let us know if that's the problem.
Thank you very much, I did a test on a model I had already made, I changed in iso and the odds that had already the two deviations I could transform them with classes and deviations :-)
premitting that I never modified the config file, now I see that
tol_display=no *
Tol_mode=limits
What effect do these voices have?
the first voice enables the display of tolerances, the second voice mode.
with limits the quotas will be of type 49,95-50,05 (if the quota is 50+/- 0.05).
Do some evidence.
the config you have to learn to use it... it is very important.
deep70 said:
...with so much desire to learn.. I am stuck with a tolerance display problem.. I managed to make everything benign to this point.. I better explain the problem:
I insert the tolerance of altitude in 3d environment then at the table I can not make it appear while in part or together there is. What am I wrong? I tried to see the config and set the tol_mode and the tol_display but I did not arrive at anything. I'm desperate. :-)
...thank you for compliments, maybe not deserved, even because I don't know how to help you see if I can help you attach an example file... it is made with the wf4 I hope you can see it other versions I have no more...
Hello to all boys
I need a handle. .
Can you tell me how you can remove labels on reference boards for geometric tolerances - like "a" or "b" on the views in here do not serve??? I put a couple of pictures so I can explain better. Thank you.
