labels on continuous facade
  • Thread starter Thread starter alpearchitetto
alpearchitetto
I wanted to ask if there's a way to assign a window-type label or if it's just like a wall.etichetta.webp
if not mistaken such label is applied in the replaced fc panels with windows or doors
Sorry about my ignorance but I don't understand. if I have only one panel (single window) for example how I can do to indicate width/height as if it were a normal window. or this is not possible, thanks :redface:
the panel (single) of continuous facade, must be replaced with a door or a window (as when in the continuous facade composed of several panels, replace one with door (or window), which must be the same size of the panel (and as model) consisting of the "only" glass.
in practice uses a door made of only glass (in the basic families there is one), modifies it with the size of the fc panel, and insert it in the fc, instead of the existing panel.
see here: http://www.cad3d.it/forum1/showthread.php?38988-quotatura-porta-in-facciata-continua
