Loutenr1
Here I am... cuffing with the paper (the discussion is always here in the forum :biggrin
, there is something that does not return to the scale of the drawing. I'm always editing the sheet format.
I can't tie the scale of the particular imported into the drawing, to the note "scale". Some soul pia explains to me the right combination between the 4 options of choice property... These...
current document.
model in the view to which the annotation is attached (only drawings). [non selezionabile]model in view specified in the properties of the sheet (only drawings).
component to which the annotation is attached
and the property scale... This...
sw-scale sheet
sw-scale view
I'm at the 40th attempt. . .
In practice I would like that once you insert a part in a drawing, the note scale changes if I change the scale of the view inserted.
:frown:
current document.
sw-scale sheet
sw-scale view
:frown:
