mat 1984
Good morning to all,
I wanted to ask you if there is in solidworks the possibility to cover in sheet of .stp files with pre-constituted bendings however to maintain the parameters of radius, thickness and factor k at the same time.
I tried 2 methods for the recognition of sheet functions. see attachments:
1: (part4.sldprt) automatic replenishment of sheet functions, I can not change the thickness: It's stuck.
2
prova2.sldprt) use function converts into sheet metal: I can't change the bending radius.
3: Attached also .stp starting file designed and converted into .stp with rhinoceros.
I also wanted to ask you what the software would allow you to do conversions in the best possible way.
Matteo
2
Matteo
