SolidUser
mike doesn't use my method, if it's yours, I don't know.mike uses the same method as mine and yours, and with the data detected it makes processing from the system integrated into the cad (and it is always the first to praise the features of swx), exactly like me and you.
simply establishes theoretical rays a priori, different from the real. Obviously based on these adjustments k to bring developments to the detected real dimensions.
the fold radius puts it almost to 0 and leaves it such if not explicitly requested by the customer.
does not use a real k factor, because if you use it in conjunction with a bend beam tending to 0, the development would be wrong.
formula :
angle * (pi / 180) * (fold radius + factor k * thickness)
How do you use a bend radius almost to 0 without altering the real k factor of the material?
