Hey, I'll hurry up like you see in the pictures! I don't know if it's the right method or the quickest but it definitely works! in practice instead of drawing a bow you have to draw a polygon with a number of sides according to the size of your shelter....after which you convert into sheet metal and the rest you know....Bye to all,
I have a small problem, I have to convert this extrusion into sheet metal and create all the bending lines so as to get this particular.
It's a shelter for a tool warehouse.
Can you help me? ?
from the image (you could have seen it on the other side, if it is empty or how) I would say that "piegatures" are not there. you have only a calandrated virole with two flat/sagomate sides welded; in one piece you cannot build it.Bye to all,
Can you help me? ?
you can draw it as an arch and extrude as a "basic flange tongue".Bye to all,
Can you help me? ?
currently solidworks 2011 supports only the operations of die-folding and rolling.Bye to all,
Can you help me? ?
Look what he wrote:that particular is a piece of sheet metal.. assembled (foot+saving), did not say he wanted it in shell.
Let's not confuse his ideas.
here are solidworks funnels:
http://www.cad3d.it/forum1/showthread.php?t=18372
solidworks does not support that type of operations....but my holder insists on having a particular bending proceeds.. .
It's true, she wrote bending... Not molding... I'm sure I'm wrong. :biggrin:Look what he wrote:
My house is called funnel.
If you want to make it welded, it can be another technical solution, but it was not the request made.
everything is related to the number of pieces you have to do a year.It's true, she wrote bending... Not molding... I'm sure I'm wrong. :biggrin:
if then his boss is willing to spend hundreds of euros for a card... .
I am sure that the version posted by bendingtoresolidworks. ( :wink: ) ... be what your boss wants, maybe with a few less folds.
The laser.everything is related to the number of pieces you have to do a year.
the cost of the single piece made imbuted or as you say of molding, just to say that we speak of the same production process, is certainly lower than that bent or assembled and welded.
if the number of pieces is sufficient, the cost of the equipment is paid back over time.
So I think it's a possible need to have it thrown out.
