layer fisso per le quote
  • Thread starter Thread starter bodofr@alice.it
I think you're both off the road. is simply the intrinsic effect of using icons and/or ribbons.
simply the user does not know which command gives, since (not reading the command line) presses the button and "that" does the quota.
Good day! my was a generic question, unpretentious and according to me with what costs me autocad, also understandable!!! I have given banally for granted that you could use a fixed layer only for quotas, automatically returning to the previous layer finished the command relative to any type of quota and I insist to say that it is not such a question out of place....regardless of how to use autocad!
Knowing your undisputed preparation I realize that you just can't do it yet...we will see in later versions! ! !
it made me smile is what of the box.... I'm sorry but I copied it from crystal!!! It seemed universally discounted however that I meant icons...so when I said traccio a quota I meant to say I press the icon of the quota that interests me to do! !
of course I thank you....and still interesting observations are coming out! ! !
However, since we are not discussing with a cold meat, after these interventions....
Please indicate the name of the command launched.
autocad does nothing without launching a command, which happens from the All-In-One bar, from a toolbar button or directly from the command line.
Now, if you want us to come over, please indicate that command you give to "trace" your share.at the limit, after you tried, type f2 and attach a printscreen of the last 10/15 rows.
...you think I can expect an answer?
the customization file has been loaded without problems. group of
customization: acad
customization: custom
customization: impression
regeneration model in progress.
Loading the autocad menu utilities occurred. ; error: no function
definition: vlr-command-reactor
command: lineacom
command:
command:
command: _line specify first point:
specify next point or [Annulla]:
command:
command:
command: _dimaligned
specify the origin of the first extension line or <seleziona oggetto="">:
specify the origin of the second extension line:
specify the position of the quota line or</seleziona>[testoM/Testo/Angolo]:
quota text = 1256.3
Sorry...
Here's bodofr, that wanted to know gp.
the command that the button (the icon) launches is _dimaligned.
In fact, I was just trying to verify that I didn't skip some [Bleep] command in the lisp instruction.
@bodow
Can you attach a dwg with just a couple of odds created with the procedure I indicated?
so it works. Danke
wanting to return to the previous layer you can use this macro:^c^c(setq clay (getvar 'clayer)) -layer;_s;"quote";;_dimlinear (setvar 'clayer clay)compared to the acaddoc.lsp procedure I suggested, this has the disadvantage that must be replicated on all "buttons" and in case of exit from the command remains on the quota layer.
Although at a time I try to report on the interesting discussion as the "green" of the autocad mechanical quotas tortures me and I would like to replace it with the most practical "0" layer by default. in c:\program files\autodesk\autocad 2022m\autocad 2022\acadm already exists the acaddocc.lsp file to which I added (load "layquote") and I put in the same folder the file layquote.lsp editing inside (setq layq "quote") in (setq layq "0") but it does not work.
it would be enough to change the mechanical standard by changing the color from green to white (layer 0 does not mean anything they simply a name and could be of any color) and then save the template
the "0" layer of default "construction" is white, which is of interest. if the "template" is meant options->am standard->iso->quote: does it but at the opening of each .dwg reappear the "green" (?). I change the macro strings one by one as suggested by gp.
Of course you reappear as before if you do not save the template or if you continue to use the previous one.
if you want to use layer 0 for building entities and quotas and then when you print have all the same lines do as well
@massivonweizen : Of course there is that if in the tab iso and quotas from the enter on apply and ok usually does not resume the problem (where we are talking about the same thing)
