layer resulting from the offset command
  • Thread starter Thread starter frankq
frankq
Hello everyone
if they are on the alpha (current) layer and create a line with the offset command, existing line on the beta layer, the new line created belongs to the beta layer.
to change layer I have to use the property command
Is there a way to create an object by offset directly on the current layer, alpha?
I hope I've explained
franc
read the offset command line, you have two options, all 2 what you said... :wink:
Yes!
specify offset distance or [Punto/Gomma per cancellare/Layer] <corrente>:specify a distance, type an option or press Enter
type layer option for offset objects </corrente>[Corrente/Origine] <corrente>: type an option</corrente>
Hello everyone
franc
I recommend frankq before opening a new discussion, reading at least or looking in the autocad help ... seems trivial to say.. But there's almost everything...
