layer
  • Thread starter Thread starter SabaGio
SabaGio
I have this problem: when I work on multiple layers, like "planimetries" and "constructive particulates", which I want to frame in a single table happens that if they have a different scale ("planimetries" 1:200 and "constructive particulates" 1:50) I do not have the possibility to see them both (by setting "show others"), while if at both imposed the same scale, type put "constructive particulates" 1:200, I only show them at the moment.
What should I do? I checked all settings and are correct. . . !
premise: actually it is wrong to use layers in different scales; is when you create the viewports that you go to differentiate the constructive details from the planes/planes, setting the viewports to different scales.
on any layer, in any scale of representation, you are actually drawing in real scale. is at the time of the table, when you create the printing sheet layer, which sets the scales and the degree of detail.
Anyway, to answer, even with layers to different scales you should see everything that is contained there. only verify that the various portions of the design are not too far from the origin (0.0), because being at different scales may have different distances, well beyond your print sheet.
I do.
