Kaji
I had to set a rectilinear movement of 78.5 mm repetitive once every 2 minutes (as order of magnitude) using a commercial pneumatic cylinder alesaggio 32 and race 80, to prevent during the last stretch the push impntasses the stem I was imposed a system of wreath and spring so that in the end the cylinder could make its 80 mm compressing the spring that through its slipper 1.5 mm.
predicted that I would simply tilt the axis of the cylinder compared to the axis of the motorcycle finding 78.5 with the trigonometry and inserting a simple snode, so the forces in place are so mechanically resible that I do not think it would inflate the flow of the structure, I wondered but from the pneumatic point of view are not simply available elementary and cheap valves that once the cylinder arrives to the "capolinea" feeling
