line thickness problem with flatshot command
  • Thread starter Thread starter sandro1274
sandro1274
good day to all, use autocad 2012 I am not professional designer but currently I come back useful for a personal project, in the past I used also inventor.
after shaping a solid
I use the flatshot command to get the various two-dimensional views, since I explore the object and move it to the appropriate layer.
the problem is that on pdf the lines of the objects I have previously exploded are
thinner than others belonging to the same layer.
example: the circle made with the rim command on the layer to has a thicker line than the view from the top of a cylinder always on the layer to!
p.s. in the window that appears with the flatshot command I however set both color and line type both on:from layer
thanks in advance for the attention.
thanks tristan,comunqiue in the doubt I have uncontrolled autocad 2012 and I put 2016
that I highly recommend to all, problem solved.
