line type scale
  • Thread starter Thread starter stephanie_83
stephanie_83
Hello everyone,
It is a bit that I work with archicad, but I just can't figure out how to set the scale of a line , for example a restraint.... a little how it worked in autocad to understand us, because after choosing the type of line, how do you set how much you want " fit "? in the curtains of the line I find no parameter that suggests this function
There is no such method of work in archicad. individual lines cannot have an independent restraint scale. the "scale" is part of the definition of the dashboard, so if you want to change it or create others, you have to use the "line types" command from the menu "options / attributes element"
