lisp for creation tiles
  • Thread starter Thread starter Bonarrigo
Bonarrigo
creation tegole.lsp
I would like to refer to the community a lisp "tegole.lsp e tegole.dcl"that I can't make it work in autocad,
after loading the lisp with autocad and running the tile command, brings error.
someone interested can help fix the file.
I attach the file tyle.zip :
creation tegole.lsp
write three times the same message, among other things not relevant with the thread in which they are inserted, is not a good start.
write in the profile the version of autocad that helps to understand the probrematics and direct the solutions.
do not post the same message in another section, wait for it to be redirected or contact the moderator because it does.
I apologize for repeating, not knowing how to submit my question to the community.
However concerning the problems detected by the lisp application
I can't run the file either autocad 14, autocad 2006 and 2007.
thank you for the kind attention, I hope you can help the correction of the router (lisp).
View attachment tegole.zip
...I can't run the file either autocad 14, autocad 2006 and 2007.
I answer here, since there has already been the intervention of massivonweizen, waiting for the "cleaning" of the moderator.
to run the lisp you must place the tile.dcl file in a folder read from the autocad path (options\file).
so how is the lisp works on autocad in English, I attach you a working version with the Italian one.
not to diminish the work of stefano puddu, but cannot you use the nets that you find on the net?
p.s.: maybe you meant "routine"
please postpone the tegole.lsp and tegole.dcl file, having accidentally deleted it. Thank you.
