lisp to convert multiple objects into contours or regions
  • Thread starter Thread starter lorenzo94
lorenzo94
Hello, I wanted to know if it is possible to convert multiple objects simultaneously into regions. I better explain, I have a kind of grid, created by lines, and I would like every "square" to be a contour to be able to extrude it. Is there a way to select all "squares" in one shot instead of having to select one by one? Thank you.
you can use the _bpoly command (contour in the ita version) and recreate the plines on the edges by clicking inside as for the retino. Then extrude them.
directly (with a selection of all lines) you will not get anything.
or you can use _presspull
That's the problem, which I should select every contour manually, but I have type 200 to create.
having to extrude regions for different heights, it is worth using premtrasc (_presspull) as already suggested by crystal.
if you have to extrude them for the same height you can use this lisp that creates regions from a grid of lines, in addition to a contour.
