lisp to transform 3d polylinees into 2d
  • Thread starter Thread starter querycad
querycad
Good morning
I am creating a lisp command to solve the following situation:
date a polylinea 3d
turn it into a 2d polyline.
the following code I ask if it is okay:
(defun c:river ()
c:river
(sject)
(setq a (ssget))
command flatten (ssget)
command explode (ssget)
joint command (p)
_
allego txt.
Thank you very much!!!
you have to understand a lot more about the lisp and its grammar
the only rows with one meaning only 1 , that "setq a" and closing
the rest doesn't make any sense in autolisp.
I'm creating a lisp command to solve the following situation. . .
I don't know if you're creating to learn or it could be a good one already done, like this attachment.
polylinea 3d is replaced by a 2d having an elevation corresponding to the share of the first summit of the original one.
Very nice
and if I want to take her to an arbitrary elevation, where do I intervene?
(cons 38 (last (car v)))) correct?
exact, if you remove the code line the elevation is set by default to zero.
I had set this feature because I had happened to work on level curves formed by 3d polylinee with vertices (of course) at the same altitude, while I needed 2d polylinee placed at that altitude.
