Furnu87
Good day to all.
I write after a long time. I have worked in the last 4 years mainly with solid works, using inventor only for sporadic changes of old projects and not having a consolidated basis for using this. now I have changed company, where they use inventor. I don't really have a role to draw anymore, but I need to use it every now and then. I know that, in the separate parts, there is the possibility to "hide" a set to display the components that make it up. I did a test by building a set1 with screw and washer, then bringing it back to a set2 (with n° 3 together1). I can hide together1 and see n° 3 screws and n° 3 washers.
But I can't do this in the existing assemblies, or the company's projects.
I wanted to ask what are the variables in play that can allow this function or not.
you differ between my test set and those present in the assemblies of the various projects there is that my set is saved on my c, while the rest is on the inventor vault. But I don't think the fact that having the axioms on the vault can block the thing...
