list prices tagbim - common of milano
  • Thread starter Thread starter gfrank
gfrank
bim prezzari: the municipality of milano is the first to seize the opportunities offered by the bim methodology for economic information management
il new code of contracts (Art. 23 c. 16) sets in place regions and other public bodies the obligation to provide each year for the updating of regional reference requirements for the implementation of public interventions.
This is an interesting opportunity: the possibility to introduce new information within the precepts that allow to exploit the advantages of bim methodology, without overturning the usual methods of use by Italian technicians.
the common of milan has quickly grasped this opportunity, preparing and publishing, in addition to the classic price list 2018, an extract of pilot items accompanied by appropriate “tags” called #takbim.What are the bim precepts and why use the #tagbim?
i Prezzari bim are precepts specifically made according to the needs of virtual modeling.
already in other articles we have emphasized the importance of tools that allow a sure communication between different models of different disciplines; is also said as a guarantee of this secure communication It is not enough only the interoperability of a non-owner format which is the ifc. It is also necessary to define a common “dictionary” that describes objects and entities in a unique and clear way for all. for this purpose the road generally undertaken, was to use classifications and coding of building products, numerous and available also in the international field (uniformat, uniclass, masterformat, etc.).
However, this is an outdated operating mode.
Today we address systems of management and control of the information attributes that characterize each object. In other words, the performance data, which intrinsically characterizes each entity used within any model (and that every technician has well known as design requirement), becomes ordering and identifying criterion, thanks to modern programming techniques.
and this is also the direction followed in the working group that is completing the drafting of the uni 11337-2, one of the sections of the Italian standard of reference for the application of bim methodology.
this direction has led to a very simple operational road to be realized, that does not subvert the normal mode of drafting of the precepts today used nor requires changes to the computer structures of the software present on the market: therefore a simple, efficient and rapid adoption system, which increasingly favours the spread of bim methods and tools.
It is ultimately a matter of rethinking the price list items, correcting them with appropriate performance characteristics that refer to the entities to which the item refers.
If, for example, we are facing a masonry, in addition to describing its material and geometry, it will be useful to insert performance characteristics, such as: thermal conductance, compression resistance, fire reaction class, fire resistance class, etc.
in this way it becomes possible to transmit the information data from one specialism to another, in economic information management, in a sure, safe and fast way.bim prezzari: the first is of the municipality of milanothe Municipality of Milan has quickly grasped the new opportunities, publishing the new price list for the year 2018 with a series of pilot voices equipped with #tagbim, in order to "to promote the integration of the price list with the most used software for digital design and modeling (bim), experimentally in this edition of the price list is introduced, for a limited number of voices, a methodology of coding proposed also in the processing of the norm uni 11337, with additional file price list 2018 xml with #tagbim.”What are the #tagbims#tagbim are structured alphanumeric strings containing attributes (#tags) that allow you to uniquely locate a price list item.
it is a question of “tag” the construction products (by giving evidence of the most characteristic properties) present in any prezzario, but also characterizing any object present in every bim model: in this way it becomes simple to realize the immediate correspondence between the objects present in a bim model and those listed in any Italian prezzario.
synthetically we can say that using a #tagbim string we have numerous advantages:
  • is an open format, can be written with any text editor, and can be read and easily interpreted by both computer and man
  • can be stored in any db (also not sql) and easily managed by any software
  • is extremely flexible and scalable (it does not require predefined and rigid structures)
  • offers very modern search and indexing modes with the use of #tags (see google, facebook, etc.)
  • is easily integrated in any precept without the need for 'revolutionary' of current uses and customs, and at the same time is a powerful tool for 'evolution' of data to the bim world
We will deepen this tool in the next article, illustrating the operating modes and the considerable possible extensions also to other operating areas.
source : acca biblus bim
