x11start
on the website http://kolbasoft.com you can freely download a "standalone" cad that is without any installation necessary.
(for the truth there is also an installable version... but it is more "invasive").
the site is really "essential", but the cad in question can be really easy to use as it almost totally autocad.
the differences concern only small things: the function keys (f1 - f2 - f3 ...) with small variations.
in the current version it is possible to import and export dwg and dxf until the autocad version 2007. autocad quotas are used (which up to a few versions ago, were not handled correctly).
the only "pecca" (hiking that it is correct in the future), concerns the impossibility of "intercepting" the blocks with the osnap or using them to cut or extend lines: you need to explode the block for this operation!
personally this cad I recommend .... as a "viewer" to those who do not own a cad: a bit like sending a pdf and then recommend using acrobat reader to open it.
