CAROLINA
Good morning.
I would like to know if it is possible to block the local delimitation lines designed to identify the area of a local, at a later time, even after drawing them?
because the lock only appears when drawn and then disappears.
Is it possible somehow to call the command??? If you like...
or I must always redesign the line and then block it.
If you like...
Thank you, darling
If you like...
Thank you, darling
