local labels revit 2010
  • Thread starter Thread starter fulviok
fulviok
in applying local labels in the various environments the areas are represented by whole numbers. from where you change your options to add decimals
thanks in advance
Thank you for answering me, but
In the label family, I can't find the option to manage decimals... .
when you are in the label family, activate the surface text, you will open an additional box, if you look down you will find a handle, click on it.
Bye.
you probably set in the project no decimal and consequently the share behaves accordingly.
Basically, you can choose whether to use the design setting or a different setting for that label.
project:
manage--measuring unit and here set 0-1-2-3-4- decimal.
label:
as said before set only for this label the values of the quota.
