location views/sections
  • Thread starter Thread starter fidippide
fidippide
Good morning, I would have always liked to place views and sections in an orderly drawing; I noticed the presence of the commands "position of elements" but I never managed to use them profitably. to align and order in the sheet the various views I always had to build auxiliary lines. Would you give me some advice? Thank you very much.
drawing little memory, I think you can simply use the grid (activating it, grid icon precisely)
command never used....... and today I took a quick look.
but what does it do with sections and views...... seems to be used to align elements such as texts or elements cmq not 3d.............. but views and sections are from 3d align themselves.
Unless you're drawing by hand.... like autocad, then I surrender xché to use the 2d of catia x draw x me is a suicide :) , and I don't know it in that profile.
but not... if you create views of a catpart views are aligned or projected automatically
Good morning, maybe I wasn't clear. I try to attach an image. in this table there are more views/sections related to several elements. I would like to be able to put them in order, align them vertically for example or with a reference. Thank you.
dx key on the view, "vision of the view" and then
"line views using elements"
so align the views, hold one and align 1 to 1 the others as you want
Great mcbramby! Thank you! We need to work a little bit and use the axes but it's a good command.
