macbook with windows and cad: delete without using fn
  • Thread starter Thread starter machepaga
machepaga
I am new to the forum, I just presented myself in the other section, however I am 34 years old and work with cad on pc windows.
I just went to the mac and obviously I have big habit problems!
I searched in the forum (it seemed even good enough) but I didn't find a real solution to my problem, or better someone found it but I couldn't do the same!
I quote the link my problem is in the second part. : http://www.cad3d.it/forum1/showthread.php?t=21405I have a macbook pro os x version 10.6.7 with bootcamp, windows 7 on which I use autocad 2010. the problem is that despite downloading sharpkeys, doublecommand and key tweak I can't delete a miserable cad line if I don't always press "fn+tasto sopra enter (or under cd expulsion key)" and also "orto" with the old f8 of windows only works with "fn+f8" (while f3 works without fn, mah!).
I hope that some of you much more prepared than me illustrate the method with some of those programs mentioned above, as the user of the link seems to have done, in order to avoid always the combination "fn+...." because two hands on the keyboard create many problems.
Thank you so much in advance,
a greeting, niccolò
