macro geometric groups - layer
  • Thread starter Thread starter gianni55
gianni55
I often receive iges that after conversion have entities on the layers but in a single geometric group. currently with the tool find and select layers reorganize them, but exceed the hundred and it would serve a macro that create the group and move the entities automatically. Someone can help me. Thank you.
hi gianni55, you have to extract the command by putting it in a toolbar and if you want to join a button to quickly recall the command changes geometric group, I know catia selects maximum 499 elements then making dx mouse disappears the voice changes geometric group, let me know if.ci aei managed, hi
like 499 elements....... I think it gets to 5000 , I'm talking about selectable elements with the find...
Hello, mastello,
Maybe you don't remember but that suggestion I gave you in relation to your problem.. .
Thanks anyway.
but my request does not concern the amount of items to select, but just the amount of layers.
I'll explain better. the elements are all in one geometric group, and they belong to different layers and these layers are a hundred!
I look for a macro that recognizes the layer, create a geometric group (number layer) selections and move entities, this for all the hundred or more layers present.
on the web there was a macro motivelayertogeoset but it does not work with my revision or with my configuration.
Hello, mastello,
Thanks anyway.
hi gianni, I'm sorry but I don't know how to help you, the only system I know is to arm yourself with holy patience and with the command you find using the layer filter move the elements in the various geometric groups.
at the moment I found a macro, but with many groups it takes a lot of time.. .
Now I'm trying with another but I have to chew visual basic and at my age teeth are grounded... :
If I can tell
It is necessary to keep the layers in order in the production of the drawing, after the first course, I confused them with the layouts, instead they are like sheets of paper millimetre, gloss paper, tecnigraph sheets and a box of pencils of different thickness, pastels. the layers 0 if used is unfairly duplicated for which, you must begin with a pre-drawn and from a specially created layers, n'1 black-white layers, then as they were photographic archives. the same goes for the layouts, keep in order, that collector.ciao
