macro meale test
  • Thread starter Thread starter Sp4rk0
Sp4rk0
hi to everyone, I wanted to ask if there is a macro that makes the angle measurement between a line and a plan, or between two floors and automatically writes the result on an excel file.
I explain better, I have to place several tilted plates compared to the xy plane, in order to be able to weld them correctly and to be able to measure them with the graduated bubble, I have to give the measure of 3 angles of reference, use me select a plate edge and the xy plane, and the angle I write it on a sheet, I do it for two sides and the top floor of the plate.
I wanted to know if it is possible to make sure that, whenever I use measure and make that specific measurement, the angle measurement was automatically written to me in a excel sheet without having to copy it by hand.
same thing if it is possible to do the same operation with the measurement of the angle between two floors.
