Core
good morning to all, use I create for 3 years but surprises never end... I created a configurable set that I configure from a txt file with the necessary parameters.
once read the file I should replace the components in conjunction with non-related components (but that have common references) with the components present together.
do you think there is a kind of macro that can make me easier to replace? I should extend it to more than 2000 components and I'm not finding any solution.
