macro to add prefix / suffix on drawing quotas
  • Thread starter Thread starter romy
romy
Good morning to all,
Is a macro possible to add a text, such as the symbol =, to the quotas of the design environment?
I often use it to indicate symmetric quotas and always do it by hand but a button that calls a macro would be convenient
Can anyone help me?
Can anyone help me?
'copyright(c) 2024 xarial pty limited
'reference: add equation to dimension using solidworks api'license: license
dim swapp as sldworks.sldworks
dim swmodel as sldworks.modeldoc2
dim swselmgr as sldworks.selectionmgr
const prefix as string = "= "
const suffix as string = " ="
sub main()
set swapp = application.sldworks
set swmodel = swapp.activedoc
if not swmodel is nothing then
set swselmgr = swmodel.selectionmanager
dim swdispdim as sldworks.displaydimension
set swdispdim = swselmgr.getselectedobject6(1, -1)
if not swdispdim is nothing then
swdispdim.settext 1, prefix
swdispdim.settext 2, suffix
else
msgbox "please select dimension"
end if
else
msgbox "please open model"
end if
end sub
selezioni la quota e lanci la macro.
ho modificato questa
Hello and thank you
works perfectly
Since you're there.... :-)
is it possible even in the box under the quota?
as from image?
Good morning.
thanks to all of you
tried both methods
a macro flaw is that the odds you have to select one by one
I don't know if you can change to have a multiselection with +ctrl
Masonic excuse
I didn't want to disrespect anyone
was not only given to me but to all users
of course everything is better
Hi giancarlo,
perfect you are a dragon
everything works and I have already customized it
I'll make it even harder...
Is it possible even on the hole captions?
I would like to add a splash to the last rigo of caption
Hi giancarlo,
Changed quickly, keep in mind that the selection quotas are of various type so that even the addition of any texts must preserve the text already present.
Since you customized the others you can try to change this by helping with the solidworks bees help.
Hello everyone,
I send the post as I used the macro politely made available to store it
But I noticed something:
when I apply the macro goes to erase the parameters of sw and practically explodes the parameters in simple text
this makes the not parametric notes and if I change for example the hole or lamatura measurement these do not update
is it possible to correct?
