maintain the original name of a saved layout with the publish command
  • Thread starter Thread starter ERMESMARONESE
ERMESMARONESE
Good evening to all,
I should publish about a thousand drawings in pdf format with the _publish command but keeping the original design name.
I explain, if I turn a file named "ciao.dwg" (only layout) in pdf, the latter will be called "hello layout-1.pdf"; I would like to keep the name of the original file.
I forgot, I use autocad lt 2011.
Thank you very much
are many, more than a thousand, and rename them one by one is unthinkable
Is there another system?
