make a measurement between two objects separated from each other
  • Thread starter Thread starter Roberto377
Roberto377
I would like to ask you for advice to make a measurement between two objects separated from each other if there is no reference point, for example, a final point, a central point, there is no remedy ?
but already delta x or delta y return the required values. or did I not understand the question?
Yes, undoubtedly, the filter is just another method that returns the same result, with the difference that, logical happens, you can apply it to many other commands.
