make climber with clone photoshop stamp 12.0
  • Thread starter Thread starter Giovannino60
Giovannino60
I imported a .jpg image then imported a photo of the climber close to this image and then from this last photo with the clone command I put the leaves on my facade, but the piece of the facade with the leaves is connected with the same image to the photo that I imported so I can no longer take off the photo that I am just servitude to clonate the leaves, how can I proceed to hold the part of the facade with the leaves clonate?
I read that you can clone between two different files. I imported the two files on the screen and flanked them, when I try to clone out this message "impossible to use clone stamp as the target level is hidden photoshop" what can I do?
Also delete you can not exit a message "impossible to use rubber as the target level is different"
You're probably on a hidden level. check the level situation.
So I heard the doctor at home, I had nothing to do with it! :smile:
How do I know if a level is hidden?
or how should I proceed if I amount two images and close them to be able to clone leaves from one image to another?
