make realistic using photos as decals
  • Thread starter Thread starter Drawne
Good morning, I don't go into modeling with solidworks because I don't know him, but I can do analogies.
It seems to me that I have understood that the faces of the polyhedron are divided into various pieces and consequently also the image is divided on each of them. Therefore it is as if you were to apply an adhesive film for car on a side, door included, and after with a cutter you have to hack the profile of the door separating it from the rest. basically the image is handled whole, and nothing changes in how many parts it is divided. by analogy the rendering should be applied on a thick part of infinitesimal thickness overlapping the pieces below, perhaps, if possible, applying a slight transparency to see also the pieces...
Do I understand?
Unfortunately the problem is related specifically to solidworks.
the question is to have the possibility to vary the position of the panels within the nesting to obtain different final solutions of the diamond rendering.
found the congenial solution to the customer will be obtained the individual panels cut the general panel on which the film is applied.
glossary:pannello master: panel or sheet on which the decal is insertedpanel nesting: panel portion representing one of the diamond faces
by analyzing the mode you want to achieve, the extreme flexibility of the positioning of the panels to change the pattern at the time of cutting, the problem is that to make the interaction between the master panel and the nesting panels all have to share the same origin. because otherwise if in the environment together overlaps pannello master un panel nesting and moves it into the desired position without common origin then cutting the panel nesting It won't be what you want.
a solution, to check and probably improveable, which came to mind is this:
-make the file part of the pannello master binding it to the origin (for example the upper left corner)
- do n file part of the nesting panels in which to model the pannello master with its decal paying attention not to bind it to the origin; shape the shape of the panel nesting inside the master panel without binding it either at the origin or at the pannello master. then hide the pannello master.
- insert into a set nesing the part pannello master in correspondence of origin
- insert a part panel nesting by displaying the sketch and placing it in the chosen location
-to change the part panel nesting and bind the origin of function pannello master to that of the witness.
in this way when the body of the panel nesting the pattern will match that of the axieme nestingwhen you go to create the diamond assemblies by inserting all nesting panels if you want to change the general pattern will be enough to change the layout of the nesting panels inside the axieme nesting (remember to manage the source point again) to update everything.
a certain disadvantage, and perhaps there are others, is that it is not possible to use the configurations so if you want to propose to the customer different solutions you have to make copies of the project.
errata corrige:
Unlike what is said before it is also possible to make configurations for the various solutions both because you can manage the origin through quotas both because the constraints within a sketch can be suspended or activated in relation to the configuration on which you are active
Hello.
I have followed this discussion with interest and, given the full contributions, I expected today to see some, although partial, solution. maybe pictures, a rendering with the features placed as a goal at the beginning. so, to understand.
I can't believe
Sorry but I have problems running sw from my laptop because it crashes, it must be a video card problem but I don't know how to fix it
Meanwhile I try to do a video driver downgrade. as soon as I have something useful to think about.
