manage connection with bolts with inventor
  • Thread starter Thread starter GianniM
GianniM
but how do you manage connections with the inventor bolts? I don't mean a single bolt, but a shit like that.
conn_134_help_use_for_web.webpOf course, okay, I create lives for lives, one at a time, but it's a very long thing!!! if you have to manage even 20 connections, with 10 bolts each, you have to create and manage 200 bolts!!! !
I tried to do tests with hyphaeature and iassembly, but without coming to the end, I found nothing worthy of note.
How are you doing? Is there any system that allows you to manage the entire connection or even better, more connections equal simultaneously?
I'm sorry, but I don't understand. If I go where you say I can put a screw at a time.
I would need something to manage more screws together, perhaps with its plates and be able to do them where necessary, with few steps.
use the series in the parts, if they are not serious there is no other way.
or on points and not by hole, but if then the screws are not all the same long six from top...
thanks for the courteous, however see the image of my first post.
there is an iron bar hypothesized hea with dishes above and below. even if I make the series for the screws I can't put the plates. and if I put them by hand comuque the series then does not make the holes on all the profiles.
so it seems to me that for inventor something similar to this is nothttps://www.youtube.com/watch?v=redunbjnhw8
