tatyb295
Good morning, I have a doubt about the window of the layout page setting.
to draw I used as a unit the meters.When I go to change the settings I can put as a print scale 10:1? I always did this way and I always found myself well with the layout on a sheet a3.
only that,as I work in meters it came to me doubt that it was not correct to use this scale,because in this case it is as if I worked in cm.
I apologize for this trivial question, but I'm at first sight despite using this program many times... but I'm often still wondering!
