mapkey e config.pro
  • Thread starter Thread starter Daniele-san
Daniele-san
Hello.
clarification on the creation and storage of mapkeys in cobfig.pro
during creation and when it happens, the modification, of the mapkeys are stored in the config.pro until here we are.. .
opening the config.pro I noticed that there are repeated mapkeys several times I suppose it is a consequence of the various changes made over time ...repeto.... I suppose
how can you do a little cleaning without harming?
you are right, if you change an existing macro, the macro text is not updated in the config, but the macro is completely rewritten again in the queue (then I create keeps good the macro version written last. )
I usually, as soon as I did an update, went to the config to clean up the old macro.
At the moment, in your case, I would make a safe copy of the config and do cleaning in the original, so that I could fish any macros deleted by mistake. .
or check the macro keys, and if you find doubles, delete the ones that in the config file are higher than the list (the index that the macro is older. . )
quoto, to clean up the config just locate the macro or save it in a "provisional package" from which then take only the new macro and replace it in the official config.
