marc to convert skinpieces to ply (composed module)
  • Thread starter Thread starter grpacenz
grpacenz
Hello all boys I have a slightly complicated problem
working within the cpm module, cpe (composed module) once a skin (father) is created, it can be split with the command
cutsplice in two subfolders (sons) with a decided overlap in previously.
if the skin (father) has a thickness of 0.3mm once divided into the two subfolders (filters) only in the overlap zone the thickness should
to be 0.6mm. when you go to generate a solid through the solid command from ply catia does not consider the overlap zone because it does not consider the subfold count (sons) but only the father skin
Now.... if you go to look at the cutpiece (son skin) you can select the contour that forms the child skin.
from here the question. .
can you create a macro that generates a new skin (father) using the contour of the child skin ...?
I know it's a bit complicated anyway thanks to the same
