FIGOR71 Guest Nov 15, 2011 #1 Is it possible to calculate the welding weight of a part or together in mass properties? Thank you. Hi.
FIGOR71 Guest Nov 15, 2011 #3 SolidUser said: The answer is yes. Click to expand... these are the property settings of the ke ho welding cord.. but whether there is ke nn welding there is mass property nn change. . . Can you help me? Thank you Attachments immagine.webp 25.1 KB · Views: 17
SolidUser Guest Nov 15, 2011 #4 welds are light, so with the measuring command, you will not find the weight, but you will find it in the welding table that in addition to taking into account your welds, will take into account the weight of the structure.
