material assignment families revit 2012
  • Thread starter Thread starter Master3D
Master3D
Hello everyone, I hope that some of you have the solution to the following problem that occurs in assigning a material to a certain family copy with revit 2012. we put the simple example of wanting to create a perimeter composed of 4 walls (basic walls) and want to assign to each wall a different material (4 walls,4 materials).
on revit 2010 I proceeded by duplicating for 4 times a system family (basic) and through the project browser I assigned the various materials to the 4 new families. each of the 4 walls was so assigned to the family consideration and I could have 4 walls with 4 different materials. I just passed to the new revit 2012 and I can't do this anymore: with the same process the setting of other duplicate families is automatically changed and all walls become of the same material. Does anyone know why? Thank you.
... sure you have duplicated the wall, and not "only" copied or removed the same wall...
I have the same problem, too.
I change the wall, I change the name and as soon as I change the material to all those who are part of the same family.
Do you have any advice or solution?
I try again and try again, but nothing to do, I duppose the walls, I renounce them, I change material, and I stick it to all the walls... where am I wrong?
