material views in shading with edges
  • Thread starter Thread starter michina
michina
Hello everyone.. .
Can you view the stone material with the graphic style model "shading with edges"? or should I import a .pat file and apply a simple retino as a surface motif?
Thank you so much!!
good the second.poi if you want you can check the flag "use rendering composition for shading" to have a "tonality" of color similar to the stone material you chose.
Hello simone, how are you? thanks to the answer; But then, when you saw that flag, which you were speaking in the classroom, I did not see the material but only the color?
Thank you!
Well well thank you... .
exact,because what you see in the materials for renderings refers to an image file,you also have,that the color is displayed only if you activate the shadows in the view.
Say hello to your partner..
