goccia
catia allows you to design objects both in parametric modeling (gsd) and in explicit (non-parametric) modeling more direct, allowing you to work also on the individual control points that does not seem possible in gsd environment.
both generate surfaces, both transportable in step-type formats.
I wonder: is there a difference between the two geometries, mathematically speaking? i.e. gsd generates better mathematicians for the proposition to video of the surface and above all it ends an industrial processing with very low tolerances?
I also noticed that modelers free forms different type rhino (in the face of greater laboriousness) allow to create geometries with a high control of continuity: is the mathematics present in rhino more poor, if so can be said, of a freestyle or gsd generation? or is it just personal preferences?
These questions arise from the fact that I am interested in producing clean surfaces of high quality, read from the mathematical point of view (reducing to the minimum the degrees of curvature and the points of control for example) for future purposes of design and industrial production.
