mating
  • Thread starter Thread starter controllofiamma
controllofiamma
Good day to all
I searched in the forum, unfortunately without result, a discussion that could help me.
I should be able to couple between them with limit couplings (which allow me therefore small movements) of elittic forms such as those contained in the image.
the same forms given their function should be able to move along the 3 axes, and also rotate limitedly to imposed values.
I hope I can be understood in my twisted explanation, but I don't know what else to write to make the idea better.
Thank you all.
solved
thanks to all and excuse the trouble
Bye.
I'm sorry if you didn't get answers for time.
great what you managed to solve anyway:finger:
Marco:smile:
Who knows if you can, even in a few words, explain how you did it? could be useful to others.
Hello Marco
bhe I solved in a way probably unorthodox, but that for the moment can reproduce the desired effects.
in short I did nothing but draw a sketch that reproduces the greater diameter of the ellipse, more than 0,50 mm.
then I paired in coincidence the terminal points of the sketch line, then set the limit values of displacement between the same points, and in the end hidden the sketches.
I already apologize if you don't understand, and I attach a micro video of the result.http://www.youtube.com/watch?v=ghnihv0viso
