Matured
  • Thread starter Thread starter Richart
Richart
hi guys, I saw that in this section of the forum there are good news about the aviation world.
I attend the last year of an industrial technical institute to address aircraft constructions, and for the tesina of maturity I would like to bring the design of an aviation part of "easy" :confused: creation; then draw it with swxi and with the same analyze it aerodynamically and structurally, and then show the work done to the commission.
the dilemma comes in the decision of what to plan, because I understand that for some parts is required a competence that I still do not have.
I hope someone wiser than me can give me "draws" and indicate the right way.
thank you all in advance!
The first thing that comes to me is the cart but I doubt that even an engineer can do it as a tesin... it would take you at least 6 months.
Otherwise you could report on an ultralight wing.
or the frame on which the motor is attached (always ultralight): it is a simple tubular structure.
or focused on the tail rudder, I don't know for example the attack plate.
Unfortunately I am mechanical and more than this I cannot help you
