maximum dimensions of a line/axis.
  • Thread starter Thread starter DoctorBomber90
DoctorBomber90
Good morning.
when I draw a line (which is full or construction), there is its limit to the value of the length I can put?
example: when I draw a line, I put immediately after its length at 999999. can solidworks display it or not?
Thank you very much
If you don't understand what I mean, I'll attach you some pictures.
the limit is not the size of a geometry, but the size of the working field, which for solidworks 2023 goes from -4999.9 to +4999.9 in x, y and z.
ah ok. because I was making the model of a planimetry, taken through the ruler from a catastral map, and each its share was parameterized with a parameter that represents the scale.
I tried to change the value of this "scale" parameter and started to give me problems (type that could not represent it/resolve it). So the problem is probably not in the fact of using the wrong constraints or if I forgot to connect quotas with the scale parameter but from the value of some quotas that "beyond" the limit allowed by solidworks. Right. @laboratoriodie?
Anyway thank you for the answer.
Right. among other things in previous versions of solidworks the limit was even narrower.
