measure distance between two lines at intervals of x meters
  • Thread starter Thread starter Riccardo Peri
Riccardo Peri
Good morning,
I have a problem, I find myself having to measure the distance between two lines a and b not parallel about 180km at intervals of 5 meters.
I would like to know if there is a lisp or some other way to automatically measure the perpendicular distance between the lines and have as final result a table where you will see the name of the point (1+005) and its distance between a and b (18m).
- 1+005 18m
- 1+010 16m
- 1+015 15m
- 1+020 11m
thanks in advance.
richer
I have to measure the distance between two lines a and b not parallel. Automatically measure the perpendicular distance between the lines...
I miss something... if I'm not parallel to the perpendicular measure of the do compared to who? !
I apologized wrongly, then, I have two lines a and b not parallel and every 5 meters I need to know the distance between them.
I had therefore thought to draw lines perpendicular to line a (type sections) which extensions will go to intersect line b.
then I would take the distance between the intersections of my "section" with line a and b.
Could I explain?
Could I explain?
This is a screen of what I want to do
