nicoganascia
Hello everyone,
I am new in this forum and more generally I am new to any forum for which you have patience if I will not make proper use of the tool. I have come here because I have a problem that has persecuted me for a long time and I finally believe that I have found in these pages the professionalism and the right skills to ask my question.
I come to the therefore, I have km and km of reliefs in which are reported 2 polylines 2d that run more or less parallel between them without necessarily intersecting (see attached file); my need is to measure the distance between the two polylines to certain progressive (with regular cadence e.g. every 10 cm or every m). the value of the measurements would serve me tabled in txt or xls format with a column the progressive measurement (10cm, 20cm......) and in the other the relative distance between the two polylines.
I don't know if I've been clear, if it were, there's a lisp that can help me?
let me know the alternative is to measure from time to time and transcribe measures. thanks to all also only the time dedicated to reading the above.
