measuring units in marc
  • Thread starter Thread starter belloinside
belloinside
hello to everyone, who could tell me how to set the units of measurement in marc?thanks
Hello, beautifulinside,
in marc (while I imagine), the u.d.m. do not set.
You're the one using the congruent quantities.
Mostly, when geometry amounts, check that the u.d.m. (normally works) are correctly read, otherwise redeem them according to the size you prefer.
normally you should use si (m, kg, s, n), if you want to use for the mm, then you should use for m tonn, so when you define masses or density, refer to this and you will still have n as forces.
bye
