mech 2013 zigzag line problema
jim78b
it will be stupid but I don't understand why sometimes opening unsaved dwg in mechanical .o dxf saved in dwg;.if I do the amzigzag line command always makes a straight line!I already set in case they weren't mechanical dwg to load my default model.
I also tried on a pc with mechanical 2011 makes the same .bo mystery.
attach a file that has that problem with inside only one of your zigzag line
ok cmq is the autocad mechanical command that goes in tilt because with mechanical drawings it works.
to make it work I have to go to the standsar type iso or ansi and force the line of the am4 layer from bylaer to amzigzag...but in theory should keep it automatically since in the dwt file I use am4 has as amzigzag line.
last thing I attach a file in which forcing a line and putting that to zig zag you see dotted instead of style zigzag cmq I saw it also with autocad mech 2011
really works properly.
Since they are not mechanical native files the settings are not those of your dwt, which has nothing to do with an existing file.
and attach two drawings (why two?) complete construction.
Do you want to have mechanical settings? simple, select all drawing and copy it in your dwt.
for displaying the line see this post (which I have not verified) https://www.professionearchitetto.it/bacheca/software/378053/problema-tipi-linee
I have attached more than one design because if not, I am not an eaustive .scusa x the excess of zeal ;)
cmq x link...to me not by errors only does not show the line correctly
Yes to copy it then the line with the special command makes it .ok just know .I didn't think that with the non-native dwg did not go .in fact also to save with name does not solve you just have to copy and paste in a new file .
Maybe you don't understand the concept of dwt.
dwt is a basic model from which you create a new design.
a file already generated keeps the properties of the dwt with which it was created.
if a file was not created with mechanical it did not acquire the characteristics of this for osmosis.
if a file was created with mechanical starting from a specific dwt can not It must be acquire the characteristics of another for osmosis othermentoi would lose those with which it was created
