braunfish
in inventor there is a way of view where the processed overmetals are for example semi-transparent? so that you have both the model to work and the model worked?
Autonomously, no, if you want to see something in this sense, you do a set where you have the outlet to work semi-transparent, and inside this you have your model worked.in inventor there is a way of view where the processed overmetals are for example semi-transparent? so that you have both the model to work and the model worked?
you can do or 2 tables, in the first position the view and as a model state put together, where you will see all the piece with overmetal and in the second table other view but as a model state put mechanical processing and you will see your piece "finished".in inventor there is a way of view where the processed overmetals are for example semi-transparent? so that you have both the model to work and the model worked?
