mgdi
after a break they are again struggling with this cam and with various problems.. and ask for help... the mechanism is assembled and "transcinating" the greater flange makes the desired movement within the desired angle limits. Now the idea is to use the "curve track" function to have a track on one of the components of the movement of the lower bearing from which then to get the profile of the cam. I did some evidence on another one and everything works. but on this I have a problem to generate dynamic analysis to use for the track curve function, surely there is something wrong in the assembly because the analysis or crashes or does not start itself. I believe that the problem can be in the assembly of the upper bearing, I have already tried several assembly solutions like "asola" but the result is always the same...
if someone had a suggestion... thank you thank you
