mediawiki for catiawiki.cad3d.it
  • Thread starter Thread starter falonef
I don't think it'll be difficult, but you have to start with the right foot.
the definition of the structure of the database with the subdivision of the arguments is the most important thing, then everyone can introduce the contributions following the scheme.
I began to prepare a list draft consisting of all the items that appear on the catia start menu with any subvoices, plus a section related to all the topics highlighted in the various sections of the forum.
Before starting to introduce data you must agree on this structure.
I proposed to the forum administrator to open a specific section on catiawiki to do all together this work. comments you can also leave on catiawiki.
Mar
I propose reusing the same structure that I had put on a while ago on this forum.
the spirit that animated me was to set the vx caty section as in the equivalent forum in germany.
the rule was to respect the sections and post in the correct sections.
example: a problem with design has nothing to do with assembly!! !
I thought it was a rule to be easily respected.After a couple of years, I was shocked to move the posts to the correct sections.:Mother:
That's why I'm not running anything anymore.
If you can put on the bases I agree with your work.
Come on.
What is this structure? Let's compare it to the evidence I built on catiawiki. the problem that you expose occurs in the forum because many....son de coccio, but should not occur on catiawiki, as they are not questions that post, but solutions: will be alone consultation.
the administrator has created a section, I propose to move there, indeed... you move everything there... seen that you are the boss.
Mar
Hello marcofa,
I don't have time to move everything. If you want to assume the role of administrator of the section catia vx I have nothing on the contrary.
Just make an official request in the forum at the super-administer.
by my green light. rest available for advice
I thank you, but I am not able for two orders of reasons:
are not absolutely familiar with the management of sites
are often absent and unable to follow a commitment
Mar
