mels a 64bit?
  • Thread starter Thread starter Jarno
Jarno
hello to all, I tried to look but I found little(nothing).
My question is simple: I have a win xp sp3 with on me10 rel 11, in case I change the pc I probably should go on a win 7 ragion x which I wanted to make a first test: the me_setup tells me that it is 16bit and so ciccia.
Maybe then the me10.exe won't go into combatability and then I'll attack, but at least the license manager, I'll hypotize, will there be an updated version that goes well, or not?
Hello and thank you.
Hello, jarno!
What does it mean to 16bit?
applications are compatible with 32 or 64 bit.
on win 7 you can install the 32 version without problems.
What version do you have of me?
it's probably like hunter says: it was an emulation already so, cmq little matter, does not turn. President, with your last sentence you mean that you have to think about it or subintend that all the software does not turn and will be to evaluate the upgrade? the license manager seemed to me that it was up-to-date by everyone, at least as reconsidered by the installation of the pe. Hi.
11 I don't remember, but he's really old.
but was it turning on native win or with x11 emulator?
Eehhh old man... that will be ever, it is of 2002:-)
However, it would be good to me since the works in me10 remain but are not, we say critical.
afair me had sold it as native win, nn has more motiv interface. How can I see if I remember correctly? but above all, if it is win there is hope for solution? Hi.
in any case if the problem is just jam, it should be possible to install the latest version to 68 thousand bits on win7.
If you install me (boh!) you should see the licenses without problems.
Surely you have to ask for a mifraction of licenses, in the sense that codewords, probably, will have to be updated with the new syntax.
to the eye and cross could also turn the 11.
try to upgrade the mels to 16 or 17 and see if me10 spins.
It's a cheap proof.
thank you andy, I have to ask you a further favor: Do you know if the mels is officially available?
I did not activate any assistance contract and tried to look for it but (maybe wrong key) I did not find, that is I find a lot of torrents, but I would like to find it official.
Now it's all gone under the toilet, right?
that I do not see them very available aggratis.. .
You can only download it if you are under assistance contract or not.
Try to hear who sold you me10 if you can provide updated version or limit another dealer, shouldn't make you so many stories.
